- Nov 25, 2015
- 8,319
Yes, drill and tap the compound and drill / chamfer the T Nut. That should give you more rigidity, and help. if you decide to use your flat washer, make sure you either grind it flat on both sides, or turn it level so it does not introduce an angle.The round marks are the outline of some washers I just put on there to get clearance. The other lines is where the square tool post would sit.
I never thought about screwing the t-nut into the casting. Do you mean actually drill and tap holes to permanently attach the t-nut to the casting? Or do you mean drill and tap a hole for the tool mount stud?
View attachment 475778View attachment 475779
edit: also make sure the washer will still allow you to get on center. if you are already tight to the bottom.
