- Nov 22, 2010
- 371
I have my Logan 820 up and running )and
Everything works, sounds quite smooth ( except for the Metal lacing ) but when I attempted to reduce the size of a 1" alum bar I cant get a smooth surface :angry:
I am using a small ( 1/4 ") tool bit HSS and it is in a bit holder that is in the "Lantern" holder in my compound rest.
The results look almost like threads I have the longitude feed set as slow as it will go on the QC gear box.
I am including a photo that is high resolution so it is BIG...I apologize for that but I wanted to give you as clear a shot as I could ( probably a waste of space)
When feeding manually I can improve the finish a bit...but not completly and I have a Compact 8 lathe so I know what it should look like.
Beside having the Emco compact 8, , I am a green horn and just surprised, silly, that the this Logan :huh:thing works at all :lmao my first lathe refurbish)
I tried the same tool bit in my emco and it works fine... I set the tool just a " tad " ( 2RCH) below center any ideas ???
The machine is almost 70 years old....but so am I ...so thats a poor excuse. The gibs are snug...I resolved cross side slop with a new cross slide nut. Everthing feels firm, tight and movable as it should
Any Ideas ???
as always Thanks
joe
Any Ideas ???
as always Thanks
joe
