- Feb 17, 2021
- 468
If possible it would be preferable to have the bearings riding on a smooth rod not the crest of the threads.Means you would prolly have to fabricate the rod.ok I get it, no drill, boring bar only which I do have just hope its small enuff............below is the project with the bolt going thru the part that rides on the bearings at both ends
I've used that approach for boring relatively small holes in softer materials like aluminum and brass. It works quite well. I haven't tried it on steel, a little worried about the relatively sharp cutting point -- but it looks like it's worked OK for you. Good to know!You are certainly welcome to use an endmill as a boring bar, I do it all the time. Just use one flute as a cutting edge. You'll need to figure out a way to mount it in your toolpost tho
-Mark
