The tap holders are cross drilled and can be used with the ratcheting handle or the small sliding T handle. The tap holders can also be used with a Gearwrench or Crescent pass thru style ratchet. It also has a die holder for hex dies.
I am thinking about buying one for my Y-Axis to move it from the left hand side to the right hand side of the mill, it'll fit when I am done.... LOLOrdered two of these Vevor power feeds on e-bay. Have installed two already on the Z axis's of two mills, and am happy with them These will be going on the Y axis of both machines. Spotted these for $98 each, which I thought was already a pretty good deal at $140ish delivered. They want quite a bit more for specific Y-axis units, and they still seem to need modification anyway, so I've just been going with the standard X axis units. Mike
Thanks for shopping with us!
When your order is done processing, we'll email info
You should get your order by May 7.
Order total: $201.87
AL-310S X-AXIS Power Feed Milling Machine 450in-lb peak 0-200RAL-310S Bridgeport
Quantity: 2
You should get it by May 7.
See order details
Quantity: 2
Ford has these too?!?Nice Ford light. Lol
was the check engine sending your wife a message? if so, you might need to go to the garage to sleep
...lift the hood, and something or other with the dipstick...Supposedly routine maintenance can do wonders for longevity...was the check engine sending your wife a message?
