I didn't see that, but I think it's the motor RPM not the spindle RPM that will show. I have a proximity sensor on the spindle that picks up a magnet with the aftermarket tach. Regardless I run the motor mainly at 60 Hz or close to that to get as much of the HP of the motor and still use the pulleys and back gears of my machinery, so I'm basically using the VFD as a phase converter, as the original machine on /off/ forward/reverse switch is wired into the VFD. I noticed on my Bridgeport that the cutter will slow when taking a heavy cut if I drop the Hz down so I try to avoid heating up the motor. I had a Bridgeport motor fry on me a while back when I was first using a static phase converter and got lucky and found a used motor on Craigslist for $50. Otherwise it would have cost me $700 to have the old motor wound.
