- Apr 30, 2011
- 29
EdK link=topic=705.msg23498#msg23498 date=1314481353 said:firbikrhd1 link=topic=705.msg23423#msg23423 date=1314408073 said:The threaded steel piece for the "T" slot that came with the wedge type from CDCO was so hard I couldn't machine it.
A friend of mine bought one of the CDCO piston type QCTP and since he did not have a mill at the time he sent the steel piece to me to mill for him. We have the exact same lathes so I could just mill it to fit my lathe. I ruined at least three end mills trying to mill that piece of steel until it finally dawned on me that it must be hardened steel. I took a file to it and could barely make a mark on it. I should have known before I started milling it because when I first looked at the steel plank I thought to myself that it had that pattern on it like it had been surface ground. Live and learn, I guess. :-[
Ed
In my case I tried to machine that piece with HSS in a Shaper and immediately learned it was too hard. I had never tried annealing and thought this might be a good opportunity. The piece was heated with a large propane torch to it's critical temperature, which was discerned when a magnet would no longer stick to it. The part was then placed in a cast iron pot filled with heated sand, covered with more sand, a cast iron lid, the entire thing covered with insulation and left to cool overnight. The next morning it was cool and machined beautifully. I left it in annealed condition as it is surely strong enough that way.
