Nelson, I have a BXA (series 200) Phase II Wedge Type and have used the same size wedge type Aloris. With a little "stoning" & "honing" (read judicial deburring) on the internals, the Phase II feels and works just as smooth as the Aloris. A less expensive Phase II Wedge type seems to be able to accommodate a larger variety of the less expensive tool holders than some of the other cheaper brands, especially if piston type.
CDCO up in Schaumburg, Ill. sells the turning & facing: AXA $8.00, the Boring Turning Facing: $9.00 each. For BXA prices just add $1.00 These tool holder prices are 1/3 the Enco price for size holder. I don't have hands on, but guys tell me they wont fit a Phase II or Aloris Piston Type without modification, but will fit wedge type.
IMHO, the quality of the Post comes first as it needs to be solid on the compound & provide a solid lock on the holder. The holder is just a "clamp" on the tool actuated by the set screws.
One caviat about the CDCO holders - the set screws are crap. However, a box of quality flat end aka flat point set screws is chump change.
Point is need only 1 QCTPost per lathe that can last a life time, but a bunch of holders which can be semi expendable, so where is the major cost over time? Right. So a good post able use less expensive holder seems to make the best economic sense to me.
I guess Platy & Paddy pretty much said the same thing re: wedge. I'm a very slow typer.
