- Jun 29, 2014
- 197
There is no way that you can swing the thread dial past the lead screw if everything is correct. You either have the wrong thread dial or something is assembled incorrectly. What happens when you engage the half nuts? Does the lead screw raise up?
I reinstalled the thread dial and engaged it and the dial started moving. When I engaged the carriage the dial stopped moving and the carriage moved without any problems. I then pushed the thread dial into the lead screw and turned the lathe on. The result was the thread dial climbing on top of the lead screw. The carriage seems to be tight enough to the ways although I can see that it looks to be a gap. I have a Thread Dial on the way here from Illinois. I pulled the carriage assembly off the lathe today, but have not had the opportunity to see what may be wrong. I believe I will find it to be something I did not assemble correctly along with the wrong dial. I downloaded a manual from the site a few minutes ago to look at the parts breakdown for some assembly help.
