- Jan 20, 2013
- 274
Hey Mark
I learn something every day! <Thank God for that!>
Yep, when Rudy Kouhoupt refers to silver solder it is "soft solder" or like you said "Bearing solder". In is nearly all Tin (Sn) with a little Silver (Ag). It melts at like 450F (or 430F). No Lead!
Wikipedia says stuff that melts at 450 and up is silver solder (not what I would say, but I've been wrong more than once!)
The NO LEAD is why I thought the plumber's solder would work... But, again Wikipedia says plumber's solder contains lead. Read up on the fall of the Roman Empire... they used LOTS of LEAD in their plumbing <YIKES!> However the "plumbing solder" I have in my torch box melts at 430F and contains NO LEAD, hence I think it is mostly tin with a trace of silver.
The FLUX is a big part of this equation too! The molten solder will only flow to where the flux is! Don't get flux on the pins of the jig and you won't weld your links to the jig! Check out Micro Mark http://www.micromark.com/stay-brite-silver-solder-and-flux-1and2-oz-each,7556.html this is similar to the stuff I got from the local welding supply store called "Stay Clean" .... Micro Mark also has "Anti-Flux". I've never tried it but apparently you paint that where you DON'T want the solder to go.
Even though this stuff melts at only 430-450F the strength is amazing!
Best regards - Dave
PS now you are jonesing to see your engine run, aren't you?
Best regards - Dave
