- Jan 10, 2019
- 1,042
It seems VFDs are going down the same marketing slope as air compressors and vacuum cleaners, all claiming big power.
As was said, hp is hp. One horsepower is 746 watts no matter how it's delivered. The OP says the VFD is running on 110V, so that means a perfectly efficient product would consume an average of 746 / 110 = 6.8 amps for every hp delivered. But nothing is 100% efficient; it's maybe 90% (for a really efficient unit), so that 6.8 amps ends up being 6.8 / 0.90 = 7.5 amps per hp. Since the mfg is claiming 3 hp output, it means that at least 3 * 7.5 = 22.5 amps is being drawn from the 110V outlet. AFAIK, no homes are wired to handle that.
MKSJ is right, a real 3hp VFD uses a 30 amp breaker when run on 220V. The problem is that the OP is trolling at the shallow end of the market for the cheapest price, and this is what you get, mfgs playing fast and loose with nonsense ratings. Physics doesn't care and will solve the bogus claims by popping your breaker before any real power is delivered.
