VFD problems.
Here is an interesting video from a guy who does company research.
That's the Bear "Den Of tools". He does a lot of HF related stuff/ reviews.
I have yet to get a really Bad product from VEVOR. The only one I would call a bit underwhelming was the 4 inch rotary table. More play and not as stiff as it should be.
Stuff that has been Good so far.
5" dividing head
Variable speed MAG drill and set of annular cutters.
Motorcycle hydraulic lift
HD feet/casters for the lathe and tables
12 volt Hydraulic 2 GPM double acting pump with reservoir
3/8" skid steer quick attach plate
2 axis DRO
12 volt diesel heater -haven't tried it yet
Motorcycle wheel adaptors for rim clamp tire machine
1 inch HD air impact- I wish I had ordered the Aluminum cased one instead of the cast iron cased 45 pounder. but so far it will either break the nuts /bolts loose or snap them off.
the 18 amp VFD, but very little use, yet.
