B&S Advertised it to help out with touching off, literally remembering where the approximate height is, rather than guessing at it or sneaking up on it and maybe hitting it a bit too hard. It is not for purposes of accurate setting, although it could function in that capacity as well, My Micromaster has the fine feeding attachment on the down feed, and the tenth graduations are quite widely spaced; feed down one tenth, and you can see the difference in sparks, it is quite sensitive, unlike the #2 grinders that I have previously had.
