- Feb 26, 2021
- 473
Do you have the factory Honda service manual for your vehicle? There may be specific recommendations regarding the process for changing the guides. For example, heat the head first, then drive the old guide out, and install the new. Either which way, you must ream the guides to the proper clearance. If you have the proper reamer, you may not need to hone them as well. What you must do, though, is perform a "valve job", and cut the seats. The new guide is unlikely to exactly match the old, so you need to true the seats to be concentric with the new guides. Neeway makes some nifty cutters, but they are not cheap.
