- Jun 12, 2014
- 4,819
There are +/-'s to each mill design, I think most people would not be able to detect the difference in routine machining. Anything will be a huge step-up from the PM-25. I prefer the knee mills overall, on my previous bench-top I started to get some sag in the head because of uneven where on the gibs over time. So if you go with a heavy benchtop I would recommend some form of counter weight system to offset the weight of the head. If you are looking at the PM-940, I would also look at the PM-833T. There is something to be said for weight and rigidity, so there is also the used market in a full size knee if you can find something in reasonable condition.
Putting a tach on these mills is not so difficult, I have made number of them, the current components listed in the document seem to work better than some of the previous ones with different hall sensors. The actual hall sensor is the same for the 8-12 mm barrel sensors. The design below is for the PM-935, but have also adapted it to the PM-949 and Bridgeport style machines. You can choose different tach enclosures depending on what you want. Using a LED light ring greatly diminishes shadows when used in conjunction with other lighting.
