Upgrading My PM 1236-T Lathe
Well it has been a few days... once again... life just seems to be getting in the way. I haven’t really made any new ground since the last post other than to fix this really annoying issue I found.
The quill lock on the tailstock had only about 15 degrees of movement to lock. It seemed really annoying because the lever was always hidden behind the tailstock body itself, and as soon as you start to move the lock lever it almost instantly gets tight.
295776
I thought that if I took 1/3rd rotation off the thread start that it would reposition the end point. That was true as far as completely bottoming the thread on the brass lock itself. Here you can see the 1/3rd rotation, and how the brass nut had moved further after removing the thread:
295777
295778
It turned out that that didn’t end up being the limiting factor. Instead the shoulder of the bolt face is what needed turned down:
295779
Now I have a much more reasonable travel of the quill lock lever. It doesn’t lock up instantly as soon as you touch it, and it ends in a more appropriate position that just “feels” more useful.
295780
Where did you get those neat little “pyramids” that hold up the tail stock when you were painting it?
Yep- Roger is right. Just some simple, plastic, paint pyramids.
Paint pyramids- who woulda thought? Let's hope a shipment of those never falls off the truck in front of me on the freeway LOL
Update time.
Let's start with the final paint stripping. The apron and carriage were the last to need the treatment.
296520
296521
296522
Masking the carriage was super tedious! Technically I didn't need to paint the bottom side, but when in Rome...
296523
296524
296525
296526
Next up was the apron oil sight. I decided to upgrade it to a glass oil sight similar to what David had used on his headstock. In fact, I also upgraded the headstock one as well. The one in the headstock did not need any machining to fit, but the apron did. This was a good excuse to use my new Bridgeport #2 boring head for the first time.
296527
296528
296529
296530
296531
After that I noticed that the oil drip pan that I made for under the gearbox was a bit too deep to fit in place when the lathe was sitting properly in position in the chip pan. So I machined off the nose and welded on a new front at the same angle as the chip pan. This was then smoothed with JB Kwik and painted.
296533
296532
296534
296535
296536
And now, the lathe is basically just as it was when it was delivered 65 days ago (sans electronics) except now it's the proper color. Ha! And wow- where did time go!?
296538
296539
296540
296541
Although, to be fair- I did apparently lose the two knobs for the spindle speed selectors, and I seem to have gained these two M5 x 35 bolts that I can't place. haha!
296542
What's next? I'm not sure. Because it's so expensive, the electronics are probably not next. I also have some plans in mind for some custom nameplates, but I think those can happen any time. I suppose I will probably start working on the DRO install since I have everything for it on hand.
Oh I forgot about this. When reassembling, I found the compound screw to be really tight. It wasn't the gib but rather the screw itself. When I looked into it, I found some serious burrs on the threads of the brass nut.
296543
I ground this down with a dremel and the screw is MUCH more smooth now. That said, I feel like I have to have the gib too loose for the compound to feel smooth; I'm thinking about finding a scraping service to address this. Also note that you can see some cross hatching on the actual threads of that brass nut. I don't think it's affecting much, but it might account for some of the initial issues. These were there when I took it apart (I didn't cause these).
296544
Speaking of issues, I also found that the threading lever was really difficult to engage/disengage. When I inspected this, I found that the gib holding the half nuts in place was so tight it was creating a LOT of drag. No amount of oil that I pumped in there was loosing it up. I ended up taking these screws out, putting some blue loctite on them, and then just barely snugged them up. Now the half nut lever is nice and smooth and easy to engage.
296545
Looks lovely, I like your choice of colour.
Will you be documenting how you realign the lathe parts? Or is this not necessary because you didn’t take the headstock off?
Thanks! Since that topic is very well documented on youtube by people FAR more experienced than me, no- I will not likely be documenting that on this forum.
Wiilly it’s looking great. I’m enjoying watching you suffer through this. Takes me back to earlier times.
