- Apr 2, 2013
- 230
After having my HF POS 3 in 1 unit sitting on a bench in pieces (took it apart to make floor space) I decided to either use it or chuck it. Since I want to do some broaching I am in need of a press, so figured I would kill 2 birds with one stone. Going to make a press that will contain the brake and sheer sections of the HF crud box, as well as being able to be used as a regular press. Shooting for a press cable of at least 50 ton (frame will do 4 times that) even though I wont ever need than much.
Have cut down the HF unit and put back together to operate by down force (none of this force up stuff) and should have it done by the end of the day. Here is a pic where Im at (need to make a back guide/brace for the upper brake section to slide on, then add springs).
Once this is done I can start on the press frame, just need to figure out what a good distance (length) would be for the legs (using 3" x 3" angle and putting casters on it). Going to dig and see if there is a standard anywhere about how long to make legs (horizontal angle) based on the height of the press to prevent tipping. Not sure if this has a name, but Im calling it the "maximum angle of tip" lol or where the center of gravity shifts to past the legs (which I will call the "OMG RUN" point)
