- Feb 2, 2014
- 1,068
Design change
I didn't like where the carburetor was sitting as it was causing several problems with other things. I moved it out in front of the engine and tipped it up 90 degrees. That allows me to make a larger round gas tank and now the carb adjustment screws more accessible. Thinking about a throttle arm to be mounted along the right side of the engine.
Do you have any suggestions?
I made and polished up a side cover for the engine. Eventually there will be a water fitting somewhere on the plate but I don't know where yet.
I also anchored the spark plug cables so they wouldn't interfere with the push rods when the engine is running.
Thanks for looking
Ray
Thanks for looking
Ray
