- Jun 12, 2014
- 4,811
Per above, this is multi-speed set by the binary 3 bit matrix. Setting the PIN 20-26 sets the speeds 1-7. These are activated by inputs D0, D1 and D3, so by switching any of the combinations of these three inputs it sets the speed control for the VFD. PN03 would need to be set to 07. So this acts as the frequency source, not a run command. It is unclear as to the setting of Pn19 "source of multi-segmented speed". This is a lot more basic VFD than the usual Huanyang VFD, so I am not sure I would put it in the same category or compare it to an HY. The manuals in these are really terrible, and I have had issues with them being buggy in some scenarios. There seems no way to set any of the motor parameters and it does not seem to run sensorless vector which will greatly enhance the motor performance. There is no way to run 3 wire control which is most frequently used with momentary buttons like on mills. If it works, fine, but do not expect a lot of functionality from them.
