- Apr 24, 2021
- 462
Just curious, should one cover their ways all the time when working, or only when sanding? Also, am I going to destroy this pm1236 by working on stainless so much?
Thank you, I have been using paper for the time being. I will look into those inserts. They will fit my shank.If you have a ccmt external turning holder then look at the number on the holder and look up the insert size for that tipe of holder. The pc9030 is the insert grade for stainless steel turning. If I am wrong, then please correct me any of our seasoned members. Can you post a pic of the holder you are using? You won't damage your lathe cutting stainless, what lathe beds don't like is gritt or gritt like paste like cast iron dust mixed with oil and grinding dust, tgat will ruin your lathe bed. The chips itself is wiped away with the way wipers. As for covering way beds, I can only suggest wiping it as often as possible and if you want you can bolt a piece of plate or plexiglass onto your carriage where your steadyrest bolt on. Just long enough so when you are near the chuck that the plexiglass or plate doesn't hit the headstock behind the chuck and wide enough to cover the bed ways. That will also help keep chips of the way beds. My two cents.
Michael.
Sorry, I don’t know how I missed this, but here is the photos.What kind of tool are you using to cut the material? And are you cutting stainless or tool steel? I don't understand your setup as described. How about a photo?
Why?Get rid of that CCMT insert and try a CCGT.
Joe
