- Jul 13, 2014
- 1,051
In the file I posted it tells how to remove and replace the crystal. that should get you to the hands and face. Page 87 step 4
Thank you.
I suppose simple deductive reasoning explains the procedure.
"Make sure the new hands are seated properly" suggests that they pressed in, and to remove them, as suggested just pry them off.
"Use small amount of petroleum based glue to secure the new dial face" suggests that to remove the old dials is just use Exacto knife or similar object to peel off the old dial.
Thank you all for the input
