- Feb 28, 2019
- 502
@dbb-the-bruce I can't speak for your suppliers in your area. That will be a research project for you if you need to change equipment.
Here are a few ideas to consider: the type of work you are doing is very well suited to a jewelry sized Oxy Acetylene outfit. There are other options, however...
Modern HHO outfits can be had from offshore for a moderate price and would work very well for the kind of SS or bronze brazing you need to do.
If you are looking to do metalworking long term, you might want to move toward TIG (bronze) brazing instead. Less finicky. fewer flow problems, but needs different and nontrivial skills to do. TIG is your most versatile but most expensive option.
The problem with MAP gas is your flame temperature is marginal to do a good job, and it isn't concentrated enough to do a long edge bit by bit. That's where HHO brazing comes in. You can do 1/2 inch of HHO brazing or OA brazing without having the SS flow out of your joint or getting burnt up - both are super common if your entire SS job is larger than your flame envelope.
I hope this helps.
What's an HHO?
I've used TIG (very little) for what I want to do it's probably to much / expensive.
Jewelry sized / hobby model sized. I can imagine (right now) anything much bigger than say a 4" cube. OA - would be nice to add to equipment, presumably on the small side. It would be nice to also be able to do bandsaw blades and braze other tooling.
