- Apr 30, 2015
- 11,309
I would just use common hardware store stuff- as soon as you get away from that the cost takes off for parts unknown
problem is there is no store stuff around here. lol iam in the sticks. nearest big city that would have that stuff is 3 hours away lolI would just use common hardware store stuff- as soon as you get away from that the cost takes off for parts unknown
??? Your sign up says you are from Troy NY. I found three relatively large chain hardware stores in Troy. Troy isn't a small town, it's a city. I've been there. Not trying to be a wise guy, just trying to help. Now, if you are truly out in the sticks, then you will have to mail order stuff. As I recall, it doesn't take much distance from the city to get quite rural.problem is there is no store stuff around here. lol iam in the sticks. nearest big city that would have that stuff is 3 hours away lol
Order it from Home Depot or Lowes and have it shipped to you for free, or to your local store. HD has the tap, the drill size you need is 19/32nd, a 37/64th will work too, but it will be closer to a 75% thread and more difficult to tap in steel. They have that too. If you want higher quality, you shouldn't have any trouble finding a place in Albany that can get it for you.problem is there is no store stuff around here. lol iam in the sticks. nearest big city that would have that stuff is 3 hours away lol
i have moved. iam as far north in ny as you can be without bein in canada. i should fix that but iam hiding from the fbi cia dea atf nsa jag dog god xwife hahahhaha joking aside. naa i moved and just havent fixed it here my bad. tho answer below for both post??? Your sign up says you are from Troy NY. I found three relatively large chain hardware stores in Troy. Troy isn't a small town, it's a city. I've been there. Not trying to be a wise guy, just trying to help. Now, if you are truly out in the sticks, then you will have to mail order stuff. As I recall, it doesn't take much distance from the city to get quite rural.
will to answer both and all...Order it from Home Depot or Lowes and have it shipped to you for free, or to your local store. HD has the tap, the drill size you need is 19/32nd, a 37/64th will work too, but it will be closer to a 75% thread and more difficult to tap in steel. They have that too. If you want higher quality, you shouldn't have any trouble finding a place in Albany that can get it for you.
