Too Large A Rotary Table
Bob, I have no idea what you are talking about.:grin:
Ah, that is only a ten wheel Freightliner. You need a heavy spec tractor with a low boy trailer for the real manly stuff. I drive a Nissan Versa, cheapest new car you can buy in America, and use Ulma Doctor for my heavy work... 8^)
Of, course, my heavy work gets delivered by two wheeled trailer...
Actually 12, has a drop down axle. ;) Licensed for 100,000 lb. 600 HP Cat The lowboy is over at my son's yard.:)
Ah, pusher axle, big bore, and low boy, you DO make the grade... Do you need permits for 100K # up there?
I use an 8", and it's all I want to lift. Dont have a problem on the Z axis on the knee mill, but I took my swivel base off the vise. Helped a lot and never used it anyway.
I was recently looking at a 8" but decided on a 6" since most of the work I envision will use it in the vertical mode. And like Bob said in post #7, it will do almost anything I want. I put a 5" chuck on it. Saved $$$ too. Easy to carry, store and mount.
