- Feb 1, 2015
- 9,619
Either W1 or O1 rod, hardened and taken to a spring temper should work about as well as anything. To harden, heat until the rods won't stick to a magnet and quench in water or oil. At this point, the rods should be glass hard and brittle. Polish the rods and slowly heat until the color turns blue and quench again. This should be a spring temper. A heat gun would probably work better for the tempering process as there is less chance of overheating. If you mess up the heat treating, you can do it over again. A propane torch and a few bricks will make a makeshift oven
