- Mar 19, 2014
- 2,681
For what you have listed. They can all be case hardened. But only the 1144 and 1040/45 can be heat treated. To make the bushings, I would try the 1144.Thanks for the info. The parts I am making will end up as drill jigs to insert into a bushing and give a reproducible line up for drilling for a locking dowel pin through the shoulder. I will be heat treating to add some durability so my question (since I don't have time right now to research).... are the 2L14, 1215, 1144, and the 1018, 1020, 1040/45 grades heat treatable?
And on another note. I did try many years ago to heat treat low carbon steel like 1018 with I think a salt/soapy water solution. I heard about it and tried it for the fun of it and it did work. For what I do in my shop though, it was not a viable plan, just a trick to remember (huh that sounds easy enough!). It’s probably all over the internet now.
