- Dec 27, 2014
- 4,056
if you have a relationship with a tool supplier
Unfortunately, I don't, never worked under my own name, I could always talk the boss into what ever was needed.
Now my needs are one or two at a time, anyway.
Use a deep enough first cut to get under the scale, then turn up the speed until you get yellow to blue chips and you will get a better finish.
How much of a cut would be considered typical for a "deep cut" to try in situations like this? I am waiting till my TGP order gets here to continue with my project, but since I have the hot rolled, eventually I will probably want to use it up.
It depends on how much scale is on the metal, but I agree with Jim Dawson on perhaps starting at about .020" with your lathe. The feed depth also comes into the equation, you would really like to keep both pretty deep. The idea is to expose the sharp cutting edges to as little of the scale as possible, which will tear them up.How much of a cut would be considered typical for a "deep cut" to try in situations like this? I am waiting till my TGP order gets here to continue with my project, but since I have the hot rolled, eventually I will probably want to use it up.
Flood coolant, use negative rake carbide tooling meant for steel with a large nose radius and as mentioned above use a large depth of cut and spin as fast as you are comfortable with.
Cutting oil is not coolant as it doesn't remove the heat. Above all try not to use hot rolled bars whenever possible, also take note that 12L14 is mostly un-weldable due to the lead content, it was developed for automatic screw machine products but has been largely replaced by 1215 due to the toxicity of lead.
For decades I heard this about 12L14 and repeated it cause I had heard it. Then a 75 year old, life long machinist called BS when he heard me repeat it. Drug me over to his shop welded up 2 pieces of 12L14 flat stock, took them over to the press, 50T and the weld started to give about the same time as material. Its not allowed for certain jobs that need to be welded, but it can certainly be welded even by a hack like me.
cheers
michael
