- May 27, 2016
- 3,469
You have a point!I have a 17. If it gets hot, the first thing I think about is my wallet. At the cost of argon refills, it will end up getting a hole burned through it.
It seems the shield gas is also, wastefully, also the cooling breeze. Sure - there is the water cooled sort, which will also definitely impact the wallet. I have had the thought that by now, we might have seen invented some passive heat dissipation tricks, heat sink fins, the creative use of heat pipes, etc.
Blowing argon back into the atmosphere in the cause of providing an inert gas shield, is a 100% total loss system (just like my lathe oilers), and the fuel energy expended in dragging the argon out of the air is a major cost, not only to us, but to the environment. This is a pity! There seems no realistic practical way to contain and recover the shield gas from around the various shaped stuff we weld on.
What we are discussing are the (overheated hand) comfort benefits of using bigger torch size, higher flow, more resource-hungry kit, all because of the inability to extract and dissipate the heat. This is an unfortunate strategy when a smaller, less costly consuming torch, would be more appropriate, and very much desired, if only the darn thing would not get so hot!
