- Jan 31, 2016
- 11,515
But I will have to touch oily gears and get dirty..............
Welcome to the club .
The flat is irrelevent . The pitch diameter is what matters .
Yes, I did check that.Not really so (that the flat is irrelevant). It could be that your spindle has a true full 60º thread, made before thread standards were adopted in the 1940's. With a full 60º thread, all your back plates would also need a full 60º thread. If you have a back plate that meets the "new" thread standard, it won't fit on your spindle, since the spindle's threads are not compatible with it.
Is your spindle major diameter 1.500"?
Be a man, use your tooth brush.But I will have to touch oily gears and get dirty..............
Yep . It was most likely turned true to the threads in the same operation . Make sure your face is running dead nuts also .So I should indicate the spindle register when I chase the threads ?
I just checked and I do have an internal threading tool that will work.If this helps .........................class 3 external thread has a max major diameter of 1.500 as you noted yours was . Class 2 internal thread has a min minor diameter of 1.365 up to 1.390 max . You should have a min of of .0022 allowance on the pitch diameters . Your root diameter on the internal thread may be small due to a broken or dull tool . If you can , just pick it up with a sharp v tool and drag it thru . From what you're saying with the thread pitch gage , it sounds like your problem .
The only thing I know after quite a few years in the shops .........................a 1 1/2"-8 internal thread has to mate to a 1 1/2"-8 external thread . If not , summpins $^*$@'d up !
