- Jan 2, 2014
- 8,853
i'm back!! set the compound at 61 degrees as per TechnicalTeds instructions. PERFECT threads.
I believe that's the same thing multiple people have said in this thread.....however it is a difficult thing to explain with words.
I am glad that @Technical Ted 's explanation made sense to you.
Did you notice this post by @Dave Paine: https://www.hobby-machinist.com/threads/threading-help.71189/post-596785
(it was in the thread that he pointed you to above.)
He shows a no-nonsense way to ensure you have the cross-slide set properly; independent of the angle markings on the lathe.
a little confused as to why everything that I have read states to use 29.5 degrees.
It depends how your lathe is marked; which end is 0 degrees and which end is 90 degrees. (90-29.5 =60.5)
The bottom line is that we got it figured out.
-brino
