cutting my first thread on a south bend heavy 10. before this i cheated and used dies. the thread to be cut is 1.00-14. material is TGP something (i forgot to mark what it is; bought it about 3 years ago). turned the TGP down from 1.250 to 1.00. using a brand new factory insert from A.R. Warner. watched Tubalcain video. adjusted lathe properly. started the cut, did everything right; and from the beginning the cut was very rough and finished rough; and, the nut won't go on. Oh, by the way, this first piece is a "practice piece". so, thinking that it is the steel, i went to a piece of 12L14. same results. the od of the round was down to .985. think, think think. tubalcain's video states to set the compound at 29.5 degrees, which i did. AND, to feed with the compound which i did. BUT, SouthBend book "HOW TO RUN A LATHE" says to feed with the cross slide. i did this first with the leaded steel; perfect threads. next did it on the excess length of the TGP. perfect threads. what is happening here????. its much eaiser to feed the cutter by using the compound and not the crossfeed dial. oh, after reviewing my post; i didn't mention that the thread cutter is also AR Warner thread cutting insert
