- Jan 4, 2021
- 1,881
Late reply (sorry!).After being unhappy with a 2 in. cutter head that uses the APMT inserts, I bought one of these on a recommendation from another member (who I would like to thank if I could remember his name).
9.1US $ 35% OFF|Sekt1204 Aftn Lt30 10pcs Carbide Inserts + Km12 50-22 1pc Milling Cutter Cnc Turning Tool Lathe Cutter Tools Cutting Tool Set - Turning Tool - AliExpress
Smarter Shopping, Better Living! Aliexpress.comwww.aliexpress.com
I've been using it for roughing down some prehardened 4140 and I'm truly impressed with the cutter AND the inserts. At 660 rpm and up to .060 DOC it is amazingly smooth and quiet. Above .060 DOC it begins to chatter some, most likely due to rigidity issues with the mill. I'm still running the first set of edges on the inserts and the edge and coating still look fine. It doesn't leave quite as good a finish as I want, so I do the finish pass with a small inserted fly-cutter. Three thumbs up!
I picked up this on eBay late last year:
Came with "Aluminum" inserts, but no arbor, so I worked a deal for the head, inserts, arbor plus an extra 10 inserts. Here's the current listing for the head & inserts (eBay item 224459253339):
I've only used it on 6061, but it does a nice job:
Should have used some cutting fluid on the final pass.
