- Aug 22, 2012
- 4,131
Hi whitmore, I eventually got my head around what you were describing I think.
The vertical line through the centre of the circle to the centre of the bearing shaft would have to be vertical in the chuck, the compound set to 2.5 degrees and the drill must be set to drill parallel to the cross slide then either raised or lowered to meet the point it must drill then advanced with the compound?
A mute point as I dont have a tool post mounted drill. (good excuse to build one though)
