- Aug 22, 2012
- 4,115
I rounded the ends at 500rpm with the 12mm end mill. Thanks to Bob Korves for suggesting the speed.
Virtually a hot knife through butter.
all 6 done with the handle I used as an aid.
To weld them to the base I clamped a length of steel to the legs as guide to keep the angles correct according to the mark 1 eyecrometer.
then clamped the foot to the upright with a large worm drive clamp.
Checking the opposite side with the two strips to ensure they were centred they were tacked in place then the foot removed so they could be welded in place.
The main tube now slides onto the feet and will eventually be bolted to the verticals.
So far its a very stable base.
And here is a teaser.
Somewhere between the two ends of the second level is where it hopefully will pivot so approximately a quarter of that tube will be cut off.
