Hello Guys,
Que I think your having similar problems as I did about 1 year ago with my TECO 7300CV. I called their help desk and a guy was extremely helpful. My problem was I was trying to use COM terminal to ground forward stop reverse switch. They advised me to ground to PE and not use COM at all for any grounding. Then set 06 to 000 which is factory default. It has worked like a top ever since. Also are you converting 220 single phase to 220 3-phase? If so they advised me to use L1 and L3 and leave L2 with nothing.
I made a drawing and took notes, not electrically correct, but thats the way I could recall this.
Hope this helps,
RWW
Hope this helps,
RWW
