- Apr 22, 2012
- 62
The problem that never goes away it seems.
Of the Half-dozen or so threads made....rough, rough. Tearing I am 99% sure.
Stainless steel. 416r and an unknown stainless. spark-tested, and magnetic.
also have seen it with common steel alloy.
Rough burrs and "strings" of steel.
Starts with the first cut at just those few-to-5 thou.
Leading edge of threads
top of threads are rough too.
HSS inserts, flat and postive. brazed Carbide
29 to 30 and inbetween.
tool at center.
60 rpm.
approx 1" dia work. 14 to 16 tpi.
Work properly and ridgidly held in 3 jaw and in tailstock
Vipers Venom oil, all over.
fishtail used carefully.
enco 13x40 lathe
lock the compound gib duringthe cut.
Can't lock the cross. DRO does not indicate any crossfeed movment.
would love to hear any and all advice/theorys.
I am getting a Wixey digital protractor to check that 30. I can eyeball with a 30-60-90....but..thats eyeball
kinda need the wixey anyway.
tool at center.
60 rpm.
enco 13x40 lathe
