- Oct 16, 2019
- 6,580
Where did you get the tap? I think I bought mine from McMaster-Carr or MSC.
I bought it from MPI tools.
It will take alot of force to get this tap started, it doesn't have the pull of a regular tap.The tap arrived today.
I drill a hole in the mild steel stock using a Z letter drill.
The tap wouldn’t even begin to bite no matter how much pressure I put on it.
So either the tap is junk or it needs a bigger clearance hole.
These taps require a LOT of force to start. Another reason to "start" the tapping with a single point tool on the lathe.The tap wouldn’t even begin to bite no matter how much pressure I put on it.
You are beginning to understand why I just bought a nut, turned a shoulder on it and pressed it in.The tap arrived today.
