- Sep 5, 2013
- 3,213
If you're looking for what I would call a maintenance set, the one you grab when you want to fix the handle on the lawnmower, Canadian Tire's hundred-and-whatever size when it's on sale is decent enough. The die stock will be the weak point.
If you want to enjoy tapping holes in your tool block that you just made, go down to Western Equipment or Raider Hansen and buy them as you need them. The difference is palpable, the cost is not as much as you might think, and they will get you through a bunch of holes if you look after them. KBC in Vancouver also sells decent ones as their house brand, so most of the time I'll order from them.
I think the worst part of any of the department store / big box store assortments these days are the lousy tap wrenches and die stocks. I bought several Groz ones for work a few years ago thinking they might be better but they were garbage too. I don't know why that is, it's such a vital part of the whole process and getting a successful thread. Keep an eye out for some older ones at the pawn shops and scoop them if you can. Night and day for holding the tools.
-frank
-frank
