- Dec 2, 2012
- 1,723
Mine doesn't haven't anything "protecting" the hole, just center drilled on flat faces.
Ah ok ,
these are the ones I saw from a supplyer I have used before.
Stu
Yes, that is it. I do not use two indicators, I just do the top and side separately. You have nice zero run out on your indicators, so the bar is accurate. The lathe is accurate, too, if the indicators read the same value at both ends. I used that for setting up my tail stock, which was way farther off than it should have been. The tail stock required quite a bit of work to get it right again, scraping the bottom of the tail stock where there was rock and poor spindle readings. Got them all back correct again. The goal when reconditioning these items is not to get them dead nuts, but to leave them set up to be correct when working against the tool pressure and wear of the parts over time. The tail stock spindle for a 13x40" lathe like mine should read about .0005 to .001" higher at the left end than the right end with the quill extended all the way and locked, and the same values when measuring on the side of the tail stock spindle, .0005 to .001" closer to the tool out near the end, compared with close to the tail stock housing, again with the spindle locked. That helps to correct for movement from the weight of the part and the pressure of the tool, along with wear over time.Bob,
Is this an example of one your scenarios. Did not do any video when moving carriage from chuck to tailstock. Note the indicator needles on both ends of the test bar.
Watch "SBL13 Test Bar Chuck Side" on YouTube
Watch "SBL13 Test Bar TS Side" on YouTube
Ah ok ,
Stu
To make protected centers, first drill the center, and then use a cutting tool with a larger included angle, like a countersink, to add a shallow cut at a wider secondary angle at the surface of the work. Then, minor dings in the end of the part will not disturb the 60 degree center cone.Mine doesn't haven't anything "protecting" the hole, just center drilled on flat faces.
Never thought about the overhang & weight, makes perfect sense though. I bought the MT5 thinking it would be best to eliminate anything in between the bar & the taper in the spindle that could introduce additional error. Plus at the time the MT5 didn't cost much more than the MT3 bar I was originally looking at. I may have shot myself on the foot on this one.
Never occurred to me to use it unsupported - that would certainly make it unreliable.
Ultimately, what you're doing is taking one center out of the equation. The MT end acts as a center and test bar, the other end is held in a center. It doesn't provide any more accuracy than using two centers and a standard test bar. In theory, it could be less accurate, because the bar taper might be off, but then so could the tapers on the centers, or the points on the centers for that matter. So in my thinking, it's one fewer potential point of failure, and it was cheaper than the non-tapered Edge product
Guys for us newbies I am having a hard time following along.Any pics would be nice of your setup on how you do both HS and tail which I need both also.Thanks for posting the Youtubes
