Thank you for joining and contributing!Thanks I actually only registered to help answer the suspension question. I literally haven't had to work with suspensions but I have a tiny bit of basic welding down. Unless you guys want to know the reason why and how to fix Honda automatic transmissions that failed from 1999 to 2006+ I actually have no clue how to use a metal lathe, or if you guys need help with body work or spraying 2k car paint or Photoshop , I'm pretty much useless here
I know this is an extremely old thread, but since it wasn't really answered directly I'll try it. what you made is fairly simple. you don't really need to overthink it. the shocks you want can probably be easily and cheapily gotten on a gocart site or ebay. get a cheap one, if it is too stiff or too weak than get a different one and just test them out by jumping on it. for example look at this videoat 21:59 he literally just jumps on it to test the suspension. it's not rocket science, there is no need to overthink it. be prepared to only tack weld it enough to test it and be prepared to make mistakes , the end result does not need to be perfect, the more perfect you try to make it the longer it will take, 4 years seems like a really long time for how small of a scale this project seems to be. the channel " Creative Channel" has 5.5 million subs, go through their videos and you will see a bunch of ideas to help you, do not copy his techniques though, for example this guy is in a 3rd world country, he is welding galvanized steel, this will kill you, it's well known. also he uses very thin flimsy metal for all his projects so unless weight is a problem I would go up a size. also I've seen it where the fabricator drills 3 different holes in a row so they can adjust the shock distance to stiffen or soften the shock. I have basic body work and 2k paint spraying knowledge so I know that bondo and some 2k primer will easily hide any mistake you will make.
This is fantI am glad you revived the thread... I have this old VW Bug front fender... and a 9HP B&S engine from a pressure washer that had a bad pump (cheaper to buy a new machine than to get a replacement pump)...
I have been meaning to make a mini-bike with those...
One of my fenders (I need to get another one... ). This is the one I installed... the one I removed is the one I will be using, but looks just like this one, only in worse condition... so perfect for this project. Just need to get the other side...
What a completed one would look like once the two fenders are modified and welded together...
The engine that I have...
I know it will require the other fender, make the two into one... but I want to see if I can get to something that looks close to this:
Good excuse to get a pipe bender and practice welding skills... The frame needs to look something like this:
And now that I have the milling machine and the small lathe, I can be more dangerous trying to make parts, buuuajajajajjajaa...
this is fantastic! Really creative and cool.I am glad you revived the thread... I have this old VW Bug front fender... and a 9HP B&S engine from a pressure washer that had a bad pump (cheaper to buy a new machine than to get a replacement pump)...
