If you mixed them all together, it would probably come out gray - I sometimes think that's why most machines were painted that color ;~)If I used up all the paint down the basement , all my machines would be either JD , IH or Cub Cadet .
In my case it would be hideous lime green, very expensive high quality 2-part epoxy paint. And a hideous "brown" (ish) that i made unintentionally made.If I used up all the paint down the basement , all my machines would be either JD , IH or Cub Cadet .
Grey?If you mixed them all together, it would probably come out gray - I sometimes think that's why most machines were painted that color ;~)
That’s the sexiest thing I’ve seen in a long time.I thought that would get your attention ;~)
Now, I bought a lathe once, that was obviously made by International Harvester (You could tell that by the heavily applied color, anyway),
but this is the first JD machine for me !
Seriously, I obviously have some work cut out for myself, here - But I had to buy it, just to save it from itself :~)
It will be a while, as I'm spread a bit thin at present, but I will come back and post, if I can produce a reasonable-looking result from this mess.
It's got the optional C&H motor saver on it too (rare)>I thought that would get your attention ;~)
A possible reason for that :It's got the optional C&H motor saver on it too (rare)>
