- Jan 2, 2014
- 8,852
Hi Susan,
That looks like a great size and well made surface grinder. I hope you can get it back into operation.
It looks like fairly minor damage considering what could have broken, depending on how that "dropped" grinder landed.
Since all the damage is at the top end close to the spindle, have you checked for a bent spindle?
You could remove the wheel, and drive belt, put an indicator on the spindle and turn it by hand.
Check the bearings by "feel" as you turn it.
Also if that grinding stone was on it during the "incident" you should at least check it over real well for cracks, if not just toss it so you know there's no risk. One trick used for checking grinding stones is to remove it, hold it by the centre hole and tap it lightly, a good one should "ring". Here's a short video that captures the sounds well:
(just the first one I found, check around for better ones with more info)
I hate for this thing to be dangerous when it's powered up!
These things spin faster than most tools in the shop.
-brino
-brino
