- Jan 22, 2011
- 8,031
Nix on that idea, there STS. If it should happen to loosen up due to side pressure, it would fall down into the work and if there is a tang on the end of the arbor, it would still try to drive the chuck and end mill. This is dangerous, and why we never recommend (nor does any factory manual I am aware of) using a drill chuck in a drill press as a milling machine in the first place.
This is NOT a valid method of removing a stuck Morse taper. Please do not attempt.
And let's not get into a discussion about proper or improper; safe or not. I'm just exercising Administrative privilege and killing that part of this thread.
