Spindle wrench
Making one will give me a chance to try the bolt circle function on my DRO :D
  • Like
Reactions: Z2V
That’s the ticket Frank!
Any idea how they ar measured?
Top of the spline?
Edit: seems that they are measured from spline to spline. I’ll see if I can get a caliper in to take a measurement.
Maybe Westen Supply would carry or bring one in.
I remember now, search for PTO coupler or adapter. Can buy em on ebay. They're used on tractors to drive external accessories or something. PTO stands for Power Take Off. Anyone correct me if I'm wrong, I don't know anything about tractors.
BTW ToT has a video on how he machined a PTO sline, the male drive though.
Edit: n/m Frank beat me to it, I type slow.
Since you have a MT3 spindle there should be a slot in the quill when it is all the way down to allow you to remove whatever you have in the quill. My Wilton Drill Press has this setup Here's a picture for you. You might have to rotate the spindle to see it.
There is a special key shown in the RF30 manual to remove what is in the quill.
  • RF-30.pdf
You can find the plans online on how to make one of the wrenches. It'll show you the dimensions you need to make it just by drilling holes. No broaching needed.
Since you have a MT3 spindle there should be a slot in the quill when it is all the way down to allow you to remove whatever you have in the quill. My Wilton Drill Press has this setup Here's a picture for you. You might have to rotate the quill to see it.
The wrench talked about here is for holding to spindle to tighten/loosen the draw bar on a mill/drill.
But guys with RF-30/31s usually just pinch the belt to hold the spindle. On my gearhead mill I would just switch to low gear. But I have a Spindle Stop now that engages the spline with a pin.
Well wadda ya know. Quick search came up with this thread here. Check post #4 by @RJSakowski
I made a spindle wrench to fit the G0755 mill and multiple others. A socket could be made to fit and a handle screwed or welded to it. A flange could be added to make mounting the handle easier.
Looking at your photo, there is not a lot of thread engagement of the spindle nut. Was the pulley modified?
Re, the spline couplers for tractors, PTO splines are either 1-1/8" or 1-3/8". The 1-1/8 coupling may work for you.
I don’t believe it was modified @RJSakowski. If it was, the modifications are not apparent to me.
I have some 10L that I might try using to make a socket similar to the drawing in your post above.
  • Like
Reactions: Z2V
