- Jan 5, 2014
- 943
I've done quite a bit of research needed to choose some improved inserts and holders for my lathe. I have a specific question about the holder.
I have a 4HP 16" lathe. I turn anything from stainless to plastic. The tool post is a quick change CXA size. Most of the tool holders are 5/8" deep where the tool or insert holder goes. I plan to start with 3/8" IC 80 Deg. inserts for now. Prior to this, I've been using a cheap set of carbide and HSS.
Does it make any real difference choosing 5/8" vs 3/4" insert holders? With 3/4", 1/8" of the insert holder overhangs the tool holder and there would be that much more lever-arm hanging from the QCTP. But, the 3/4" might be more rigid? My gut is saying 5/8" is the right answer but my head is swimming from the tens of thousands of choices there seem to be with inserts.
What is your experience? Are there other advantages or disadvantages for a larger shank insert holder?
