- May 26, 2015
- 864
For Gins Then:You're jumping the gun. Get your spindle properly installed/shimmed BEFORE you do any other measurements like this.
OD CHUCK MOUNT PLATE .003"
BACK CHUCK PLATE .0015"
SPINDLE NOSE .0015"
Yep...what he said. Take the chuck off and measure at the spindle.You're jumping the gun. Get your spindle properly installed/shimmed BEFORE you do any other measurements like this.
Not yet. I just today got the headstock tightened down and will do some dial indicator testing tomorrow. "If" after doing a thorough testing of the chuck, and found not true, I may buy an import chuck and back plate. The one I have now was made in India. That would be less aggravating than trying to grind the chuck jaws. Anyway I don't have a tool post grinder to do that task. As my best guess right now the chuck is going to need replacing. "MORE MONEY" and the Lathe God's are mad at me! LoLHave you tested the spindle play by inserting a rod in the spindle and pulling up and down and checking the play?
Don’t worry about chuck runout until you’ve verified that the spindle is within spec.
