- Jan 2, 2014
- 8,852
Do they look worn to you or are they ok?
They look great from here!
-brino
btw, I really like that grey paint!
Yes it does rotaye 360 but the degree marks ate at the rear of the compound.The compound slide should be able to rotate 360º. If it can't, you're doing something wrong. Look at the shoes that fit into the dovetail.
This evening I was putting the compound slide back together and noticed the only way it could fit is with the degrees pointing toward the rear of the lathe. "Is this correct?" I spent two hours trying it forwards and backwards and it will only fit one way! Can post a pic in a little bit if this doesn't make sense.
