    Dismiss Notice
Some Useful Milling Machine Tools
Discussion in 'TOOL JUNKIES - TOOLS & TOOLING (Love Tools? This Is Your Forum)' started by Nels, Sep 27, 2010.
  1. Nels
    Nels United States Founder Staff Member H-M Supporter-Premium
    762
    113
    Eastern Queens, NY
    City:
    Eastern Queens
    State:
    New York
    -Return to Top-
    ? endmills and weldon flat endmill holders, various shapes and sizes.
    ? stub length drill bits
    ? hold down sets for mill
    ? dovetail cutters
    ? t-slot cutters
    ? horizontal/vertical rotary table
    ? tilting angle base compatable with rotary table, if it isn't built in.
    ? collets
    ? tailstock to go with rotary table
    ? milling vice - consider kurt as the chinese ones can leave a lot to be desired.
    ? swivel base for vice
    ? toolmakers insert vice
    ? clamp down sets
    ? boring head for mill and boring bar
    ? parallels for holding work up in the vice
    ? slitting saw arbor and blades
    ? fly cutter
    ? fishtail threading gage (for aligning tool to work) and an ACME screw thread gauge.
    ? metal, plastic to cut (online metals has some assortments but you will need some bigger stuff as well)
    ? reamers
    ? angle blocks for setting up work at an angle in vise, measuring, etc.
    ? spiral point (best for through holes) and/or spiral flute (blind holes or through holes) taps, tap wrench
    ? countersink bits
    ? transfer punches
    ? cam clamps or toe clamps
    ? machinists? parallel jaw clamps, c-clamps
    ? machinist squares
    ? right angle blocks
    ? 123 blocks, 246 blocks
    ? Machinists? jacks
    ? edge finder and/or wiggler
    ? gear cutters or free running hobs, or a fly cutter style
    ? deburring tool
    ? DRO (expensive, optional)
    ? radius turning attachment (optional)
    ? better drill chuck for mini-mill
    ? expanding mandrels or arbors
    ? vice work stop
    ? steel letter/number stamps sets
    ? v-blocks
    ? ring light for mill
    ? x-way cover for mill
    ? way lube/spindle lube
    ? tachometer
    ? horizontal bandsaw for cutting stock, bimetal blades. In a pinch, you can cut them on the mill
    Some sources: Shars, Travers Tool, Enco, MSC, Grizzly Ind., Tools4cheap, CDCO, Little Machine Shop, Ebay, Machine Shop Discount Club, Reid Tool Supply, Anytimetools.
    Please feel free to add to this list!
    Best,
    Nelson
  2. Corm
    Corm United States Active User Active Member
    0
    16
    City:
    Fairfax
    State:
    Vermont
    -Return to Top-
    A square and a hex collet block comes in handy once in a while also.
    Corm
  3. oscer
    oscer Active Member Active Member
    0
    6
    -Return to Top-
    I knew I needed to spend a lot of money tooling up Nelson but I hadn't made a list, just thought I would buy as project needs dictate. I'll probably spend more on tooling than I paid for the mill. Maybe I'll make a copy of the list you posted and see how many years it takes to fill it.
  4. altobe
    altobe Active Member Active Member
    0
    6
    City:
    Toledo
    State:
    Ohio
    -Return to Top-
    I found this company while watching machining videos on youtube. Glacern Machine Tool http://www.glacern.com/
    Their tools look to be top quality and I especially like their vices and various tooling.
    Their videos are awesome and for anyone that is interested in machining these are very good entertainment! :nerd: Beside their product showcase videos they have a whole series called, "crash course in milling", that's pretty good. Although its geared to showcase their products they are very well made and also provide some basic info.
    Also I am not affiliated with these guys in any way just thought I'd share as they appear to be pretty high quality tools. I have no first hand knowledge but I've read that they have extremely good customer service.
  5. Robert62
    Robert62 Active Member Active Member
    1
    8
    -Return to Top-
    A tramming alignment tool to make tramming and setting up the vise quicker.
  6. RyanHarris
    RyanHarris Swarf Registered Member
    0
    1
    City:
    chandigarh
    State:
    Nebraska
    -Return to Top-
    spline broaches
    The spline broaches generates the splines by the top of the tooth and by cutting of splines and to finish hole into a component. Spline Broaches are utilized for manufacturing purpose to form holes or cut the surfaces. A variety of spline broaches are available according to the specific work to be taken from them.
    Fore more information please visit capital-tool.com/broaches
  7. Pkranger71
    Pkranger71 United States Iron Registered Member
    0
    1
    City:
    Bradley
    State:
    California
    -Return to Top-
    In regards to the Glacern Tools, I have their 5" vise, er32 collet holder and drill chuck. Being new to machining I could only compare them to the cheaper "enco specials" I started out with and the difference was day and night. These are quality tools. They also ship very fast. I am not affiliated with them in any way, just very happy with their tools :))
    Matt
  8. gi_984
    gi_984 Active User Active Member
    51
    28
    City:
    madison
    State:
    Wisconsin
    -Return to Top-
    I have a Glacern 5 inch machinist vise as well. Very happy with it.
  9. ARM
    ARM South Africa Active User Active Member
    70
    28
    SOUTH AFRICA
    City:
    DURBAN
    State:
    Outside US / Canada
    -Return to Top-
    How'dy MATT
    Compliments of the season to one and all.
    We just ordered an R8 Integral Drill Chuck from them after looking at an Albrecht, which we wanted in a 5/8, which regrettably they did not have.
    However, comparing Price and their TIR precision quality, we do hope we have made the right decision.
    We did burn our fingers buying locally, what we refer to here as a Fong Kong Product !!!
    Looking forward to our Delivery.
    Kindest regards
    aRM
  10. gmcken
    gmcken United States Active User Active Member
    5
    8
    City:
    Independence
    State:
    Virginia
    -Return to Top-
    I needed a way to assist in tramming in the Bridgeport so I made a surface plate out of a used brake disc. The disc was turned on a 12" atlas lathe using back gear. I checked the disc after turning on a surface plate with very little run out. to use, clean mill table, lay disc on table and use dial indicator to tram in head. Works better than trying to work around slots in mill table. I check the mill head before starting to align the vice.
    markba633csi likes this.
  11. Xiansheng
    Xiansheng Australia Active Member Active Member
    1
    8
    Point Halloran
    City:
    Victoria Point, Queensland
    State:
    Outside US / Canada
    -Return to Top-
  12. Xiansheng
    1
    8
    Point Halloran
    City:
    State:
    Outside US / Canada
    -Return to Top-
    HI. Re the list of useful tools, is the list backed up with plans and the like, or just a wish list?
  13. RIMSPOKE
    RIMSPOKE United States Active Member Active Member
    379
    63
    City:
    WAKE FOREST
    State:
    North Carolina
    -Return to Top-
    HERE IS ONE THAT I HAVE FOUND USEFUL FOR THE MILL .
    IT IS AN R-8 COLLET WITH A 3/8" HEX HOLE IN IT . I HAVE NEVER SEEN ONE ON THE MARKET .
    IT WAS MADE FROM A NORMAL ROUND COLLET WITH A WIRE EDM BURNING THE HEX HOLE .
    THIS MAKES IT EASY TO MOUNT TOOLS IN THE SPINDLE THAT NORMALLY USED IN A DRILL CHUCK .
    IT WORKS WONDERFULLY WITH A SET OF LENNOX HOLE SAWS . NO SLIPPING !
    royesses, 4gsr and ARM like this.
  14. dlane
    dlane Active User H-M Supporter-Premium
    530
    113
    Lake oroville
    City:
    Oroville
    State:
    California
    -Return to Top-
    T slot cleaner / chip brush , magnifying glass , squirt bottle for wd40, chip deflector , broom/dust pan.
Share This Page
