- Sep 22, 2010
- 7,222
? quick change tool post and holders
? cutoff tool and holder
? knurling tool
? lathe cutting tools, including inside and outside threading. HSS and maybe indexable carbide
? follower rest
? steady rest
? live center
? lathe faceplate
? collets
? 4-jaw independent chuck
? boring bar for lathe
? carriage stops and carriage dial indicator holder for lathe
? tailstock drill chuck with taper adapter
? lathe dog, dead center for lathe spindle and faceplate or driving plate
? milling attachment for lathe
? center drills
? assorted files and wet/dry sandpaper
? horizontal bandsaw for cutting stock, bimetal blades.
? bench grinder for grinding lathe bits. Wheels, incl. a diamond wheel if you want to sharpen carbide. Grinding wheel dresser.
? lathe tool blanks, for grinding
? belt/disk sander
? Swing arm magnifying lamp, mounted over lathe/mill
? way lube/spindle lube
? safety shield with mag base
? center punch
? scribes
? reamers
? stub length drill bits
? countersink bits
? metal, plastic to cut (OnlineMetals, SpeedyMetals, etc).
? A shop vacuum
Some sources: Shars, Travers Tool, Enco, MSC, Grizzly Ind., Tools4cheap, CDCO, Little Machine Shop, Ebay, Machine Shop Discount Club, Reid Tool Supply, Anytimetools.
Please feel free to add to this list!
Best,
Nelson
? knurling tool
? follower rest
? steady rest
? live center
? lathe faceplate
? collets
? center drills
? belt/disk sander
? center punch
? scribes
? reamers
? countersink bits
? A shop vacuum
Best,
Nelson
