- Dec 26, 2015
- 2,082
Where did you find your Boyer?Seems high to me. A Boyar Schultz 6x12 is just a bit bigger and they sell for way less.
I think your experience is the exception rather than the rule. I paid less than $700.00 for my Sanford MG. It didn't need any repairs, or even a cleanup. It came with a chuck, a wheel hub, and half a dozen assorted wheels. I think the key to determining the condition of a machine is to be able to run it as part of the inspection process. Many of the defects you found after getting it home would have been revealed had you been able to run it before purchasing it.rjs - you hit the jackpot. I paid $600 for my 618 Ingar, it was in pieces, the traverse hand wheel was broken, and the shaft was bent, the traverse belt was broken, it could not be run tested, it was very dirty, there was no magnet, there was nothing for tooling and I couldn't be sure all the pieces were present.
The good of my purchase is that I could see the ways, and the looked good. Perhaps that is a benefit of a manual machine? The table only moves when someone is standing there, to wear it out means a lot of hours - so if someone has that much work for a surface grinder, then it makes sense to get one with some automation. I felt this little machine had decent bones. After considerable effort, making parts and tooling, purchased a mag table, I could finally start to play. I discovered the spindle bearings were bad, more tool making, $500 for bearings. All in I have about $2000 and perhaps 300 hours of effort. Perhaps I'm dilluded, I think I got a good deal.
This one is 625 lbs !You might be better off with this one.
That's about what mine weighs. Keep in mind the chuck (approximately 35 lb.) can be unbolted from the table, the table ( approximately 65 lb.) can be lifted from the base, and the machine can be removed from the cabinet. The cabinet itself weighs around 75 lbs. The remaining structure should weigh around 450 lbs. That should be light enough to move with an appliance or similar type dolly.This one is 625 lbs !
That might not be as expensive as you think. My shop is in the basement and has several large pieces of equipment including a Bridgeport mill, Sheldon 13" lathe, Startrite horizontal bandsaw, Racine power hacksaw, Seneca Falls Star #20 lathe, US Machine Tools horizontal mill, and a number of similar size machines.With a bad back, I would have to pay someone to move it into my basement shop.
The small one would have to be broken down so that they can be taken down into the shop.
thanks
