- Feb 21, 2022
- 770
The quill can sacrifice some structural strength for high surface hardness as it has a relatively large mass & needs to last a long time. It is a prime part for case hardening allowing a very high surface hardness for wear resistance and a durable core for strength.I would venture to say the reamer is harder than the hardness of the quill by a slight if not large margin.
There’s really no need for the quill to be harder than it would need to prevent undue wear.
The reamer absolutely needs to be as hard as can be without being brittle.
A reamer also needs to resist wear without being too brittle so it can withstand cutting forces on the small sections of the flutes. I suggest that the hardness of a reamer is less than the surface hardness of the quill.
If we consider the taper on a reamer or drill, they are soft and welded to the hardened cutting portion.
Yes, my post said that the hardness of the quill was relatively greater than the soft tapers on drills and reamers.Hardness is relative. Hmm, you might be on to something, it's hard to tell if the reamers were cutting or putting new metal in. the finish could have ended up looking good either way.
I doub't if your reamers were putting new metal in, perhaps someone can enlighten me how this happens.
The quill sockets generally don't wear, more often they pick up galling from soft spinning tool tapers. Morse taper reamers remove this soft galling and should not cut the original taper, preserving the original alignment and geometry. Another reason why morse taper reamers aren't as hard as the quill surface.
